Slow to start - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
post #1 of 14 Old 05-24-2006, 06:10 PM Thread Starter
GarricksSentra
Quoted: 0 Post(s)
(Thread Starter)
Slow to start
So my '04 1.8s is still pretty much brand new. 22K+ miles. But now sometimes it takes a bit to turnover. Quite noticably too I might mention. It's always been a split second to start. Now it sometimes takes 3 or 4 seconds. Is this just the car showing age or a sign of a potential problem? Should be covered by warranty right? If so, a quick diagnostic check at the dealership should do me huh?
No Sentra, No more.
GarricksSentra is offline
post #2 of 14 Old 05-24-2006, 08:12 PM
SpecV_USMC
Quoted: 0 Post(s)
Send a message via AIM to SpecV_USMC
i had that prob with my 03 spec. for me i thought it was the battery, then it made a clicking sound from under the dash a couple of times while i was turning ignition on, then about 4 weeks later, it clicked and didnt start. It ended up being my bat terminals.
SpecV_USMC is offline
post #3 of 14 Old 05-24-2006, 11:26 PM
ghost_ryder35
Quoted: 0 Post(s)
Send a message via Yahoo to ghost_ryder35
maybe turn the key to the acc position and let the fuel pump prime, then it should turn over right away. make sure you get all the recalls done
Yes, suspension should be first. I quote BMW by saying "Power is nothing without control"
ghost_ryder35 is offline
post #4 of 14 Old 05-25-2006, 12:14 AM
SpecV_USMC
Quoted: 0 Post(s)
I had to start doing that too, figured it was due to the nonservicable filter... POS if u ask me, bc ANY filter will, if its filtering, will eventually clog. So with age, 40kmiles for me, the flow had slowed down enoght that i had to let it pressurise b4 startup
post #5 of 14 Old 05-25-2006, 05:48 AM
jcrow
Quoted: 0 Post(s)
Same problem as my 03 GXE. It turns out to be the fuel pump pressure regulator. There is a TSB (technical service bulletin) on this issue. Look here. http://www.nissanhelp.com/Ownership/.../NTB05-052.htm Check your battery voltage and making sure it has good connections if that does not help print out this TSB and take it into the dealer, that if you are under warranty. I don’t know if that is a common problem but lot of people have this issue. Oh yes for some reason the "prime the pump" didn't work for me.
GarricksSentra
When do you have a hard time starting? Cold, hot, or warm engine? Right after you turn the car off or has been sitting for two hours or so? Or even over night?
03 GXE VIBRATE BLUE
k&N Drop In Filter / SS brake lines.
RIP DEC 2008
08 Versa SL
61,000
Sold
12 Rogue AWD
jcrow is offline
post #6 of 14 Old 05-25-2006, 02:19 PM
ghost_ryder35
Quoted: 0 Post(s)
no its not because of a nonservicable filter. It's because the pump has a bad valve, which causes it to loose pressure when the car is turned off. that is why you need to let the pump prime before trying to start, that way it is pressurized again.
post #7 of 14 Old 05-25-2006, 02:49 PM
1SentraNotEnuff
Banned
1SentraNotEnuff's Avatar
Quoted: 0 Post(s)
it's the fuel pump. they need to replace the whole thing under a recall. i had that same problem.
1SentraNotEnuff is offline
post #8 of 14 Old 05-25-2006, 05:57 PM Thread Starter
GarricksSentra
Quoted: 0 Post(s)
(Thread Starter)
Does anyone have a reference for this recall? If so I'll take the car right in to the dealer. I've never heard of any. Is it as simple as searching for it on the NET?
No Sentra, No more.
post #9 of 14 Old 05-25-2006, 07:59 PM
jcrow
Quoted: 0 Post(s)
It is not a recall. It is a TSB (technical service bulletin) and that number is NTB 05-052
NTB = Nissan Technical bulletin.
TSB is the same thing as a NTB
03 GXE VIBRATE BLUE
RIP DEC 2008
08 Versa SL
61,000
Sold
12 Rogue AWD
jcrow is offline
post #10 of 14 Old 05-26-2006, 04:06 AM
viper_fan
Quoted: 0 Post(s)
i had problems starting too, turns out it was the fuel pump...they replaced it under warranty. now im gettin over 30mpg highway i kid you not!
viper_fan is offline
post #11 of 14 Old 05-26-2006, 04:58 AM Thread Starter
GarricksSentra
Quoted: 0 Post(s)
(Thread Starter)
How did yoy know about this buletin? You would think they would mail or call each person who it might affect.
No Sentra, No more.
post #12 of 14 Old 05-26-2006, 05:59 AM
jcrow
Quoted: 0 Post(s)
Well, a bulletin is way different then a recall.
A recall almost has to do with the safety of you and or the car. (or emissions) A bulletin has to with a common problem that has nothing to do with the safety of you and or the car. It outlines detailed instructions on how to fix the problem. In some case a bulletin is issue when there is a new procedure on how to fix something on the car. So as you can see there are not going to mail each owner of a car if there is a new bulletin. In most cases if your car is out of warranty they will not fix the car for free from a bulletin. www.nissanhelp.com has all the recalls and bulletins for all Nissans. Just take a look at the recalls and TSB’s for the car you will get a better understanding why they don’t contact each owner of the cars.
If everything checks out ok (your battery, loose wires) and it looks like your car is under warranty then you can get this TSB perform on your car. The kicker is to have them “duplicate” the problem. I had a hard time duplicating the problem. On my second time I was there the car started fine and the service guy just looks at me and says yep I know what you are going threw I have a sentra to. So he writes up, car had hard time starting, replace under 3/36 warranty. Well good luck.
03 GXE VIBRATE BLUE
RIP DEC 2008
08 Versa SL
61,000
Sold
12 Rogue AWD
jcrow is offline
post #13 of 14 Old 05-26-2006, 06:48 AM
Y2K SE
Moderator
Y2K SE's Avatar
Quoted: 10 Post(s)
Garage
The service bulletin does not replace the fuel pump.
Current:
2011 Navy Blue Metallic Nissan Altima 3.5SR Sedan
Previous:
2000 Heatwave Nissan Sentra SE w/ Performance Package | NISMo Suspension | NISMo 17x7.5 bronze wheels
Y2K SE is offline
post #14 of 14 Old 05-29-2006, 10:25 PM Thread Starter
GarricksSentra
Quoted: 0 Post(s)
(Thread Starter)
Well good luck.
Thank you very much.
No Sentra, No more.
User Tag List
