B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Modifications - Performance
B15Sentra.net is the premier Nissan Sentra forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 02-16-2006, 05:26 PM   #1
Trav4011
Hoosier Daddy?
Send a message via AIM to Trav4011
Here it is! Finished VQ35DE install kit!
VQ35DE Swap kit (2002-up Spec V/SE-R)
Water-Jet cut/TIG welded 321 Stainless mount adaptors
Modified VQ35DE engine brackets
All bolts/nuts/washers/shims needed
VQ35 bellhousing to swap onto your Spec V trans
Axle bracket/adaptor to use your Spec V axles
All seals, pivot ball installed in bellhousing
CD with install pics, instructions, diagrams
(Optional) Solid front mount
Bolt-in VQ35/VQ30 into your Spec V. The ONLY modification that you have to do.. is grind about 3/8" off of the post on your rear engine mount for clearance, and drill out your front engine mount to 1/2" to accomodate the larger/stronger 1/2" bolt that I use in the kit. You can still use your rear motor mount inserts if you shave them down to fit in the Maxima Bracket. The front inserts COULD be use, but you will need a large diameter washer to put behind the bolt to hold them in place. I am going to offer a solid front mount if you guys want it. This will eliminate ANY wheelhop, and there is very, very little noticeable vibration from using it. If you make the front mount solid, you can leave the rear mount stock. During testing, on slicks, I experienced almost zero wheelhop using this method. If you want a solid mount, you may buy the mount from me, or send your mount into be modified for a small fee.
There is one problem that I am having right now. The VQ bellhousings are on backorder. I got the LAST one from Nissan for this kit. I have 5 on order, but I'm not sure when they will be coming in. Nissan has not given any release date as of yesterday. You CAN buy a VQ 6spd trans from a 6spd Maxima. It MUST be the LSD transmission.. otherwise, the axle bracket will NOT work.
I am not allowed to post pricing on this board.. if you want more info, please check out TheVBoard for that, or PM me privately. But, please feel free to post technical questions in this thread, and I'll do my best to answer them in a timely manner. Thanks.
Travis
2004 Mustang GT- *Under construction*
2009 Pontiac G8 GT- Cold air and a tune..
Trav4011 is offline   Reply With Quote
Old 02-16-2006, 05:32 PM   #2
Damian
excellent job, thank you for sharing your "mad scientist" skills.
Damian is offline   Reply With Quote
Old 02-16-2006, 07:04 PM   #3
wazmunstr
100k Miles
sweet man. how much? haha im kidding. nice work.
se-r_spec_v|obx header|megan mid-pipe|aem dry-flow|aspec cold air intake|optima redtop|koni sport yellows|eibach pro-kits|revolution_autoworks torque damper|kenwood headunit|
wazmunstr is offline   Reply With Quote
Old 02-16-2006, 07:04 PM   #4
Arvin
2004 Blackout Spec-V: ES mmi, Razo knob, Tein s.tech, Faktion SS, XS Power Header
Arvin is offline   Reply With Quote
Old 02-16-2006, 08:00 PM   #5
SentraGTi-R
Send a message via AIM to SentraGTi-R
titanium bolts would be nice travis lol jm. good job man. ill have to subscribe to this for future reference.
de.m3nt'D O_o'
|o2 sPec V|
SentraGTi-R is offline   Reply With Quote
Old 02-16-2006, 08:12 PM   #6
Dangling Fury
that's a bingo!!!
Dangling Fury's Avatar
Nice work Trav, very impressive. So this takes care of the mechanical part of the swap.
However, this swap kit is not complete, what about the electrical? I remember you mentioning that the wiring was a complete PITA. Are you going to be providing a wiring harness along with this kit?
Originally Posted by Trav4011
You guys are going to HATE doing the wiring with this swap.
The Altima has it's ECCS relay, and Accel pedal relay+wires going into the car, on the driver's side in a fuse/relay box.. The Spec V has it's relays/harness behind the glove box.. Needless to say, all the wires are the wrong colors.. so, I am having to disect each harness and trace the route of each wire. After several ibuprofen, and almost an entire day.. I THINK I have it sorted out. Now, it'll just take me another entire day of cutting and soldering to get it to work. What a pain..
2006 Mitsubishi Evo IX RS (300whp/298wtq)
2002 Nissan Sentra SE-R (sold 7/26/07)
Central Carolina SCCA (Autox for NC/SC)
Originally Posted by zillafreak View Post
but i get paid to listen to my coworkers, not to surf the web.
^^^ fail, work blocks youtube.
Dangling Fury is offline   Reply With Quote
Old 02-16-2006, 08:17 PM   #7
Trav4011
Hoosier Daddy?
Yes, this kit takes care of the mechanical end of the swap.. You are responsible for your own wiring/ECU options. It's simply too time consuming for me to offer a cost/effective sollution for you guys. I don't have the time, and most people don't have the money for me to do it. Also, it's much easier to "build" the wiring harness onto the car with the engine in. You have to use parts of your QR harness as well as the VQ harness. I WILL, however, provide diagrams, free of charge, upon request. And tech support for wiring, within reason..
Travis
Old 02-16-2006, 08:25 PM   #8
Dangling Fury
that's a bingo!!!
Cool, thanks for clarifying. Anything else? So, other than the actual VQ engine, you need:
1. Mechanical Swap Kit (pictured in this thread)
2. Wiring harness
3. Intake/Exhaust piping???
4. Belts/Hoses???
5. ???
Old 02-16-2006, 08:50 PM   #9
DevlynSyde
OT Whore
DevlynSyde's Avatar
Send a message via AIM to DevlynSyde
Number 5 is patience and extra spending cash
Vote Dev for OT Mod
Because Children Can't Handle Power
2001 SE - AEM Intake, HotShot Header, HKS Exhaust w/ Super Drager Tip
DevlynSyde is offline   Reply With Quote
Old 02-16-2006, 09:33 PM   #10
shift_boom
This shouldn't cost you more then $5k. There are plenty of VQ's in the US - you lucky bastards have so many to choose from, unlike here in Canada were there is only a small handful.
06 OBP STi
02 Blackout Spec
I/H/DP/E/KDW2's/ES MMI/04 Tails/Nismo Suspension/Nismo RSB/Nismo Stickers/Ground Wires(+5WHP) (GONE)
shift_boom is offline   Reply With Quote
Old 02-17-2006, 08:44 AM   #11
kasonb
The Emo Kid
kasonb's Avatar
Send a message via AIM to kasonb Send a message via MSN to kasonb
so wait...it costs $4500 for the kit?..i thought it was $4500 for the full install...im confused because there is no way i could do this swap myself...
2003 Nissan Sentra Se-R Spec V
Originally Posted by FuLIsh
please stfu
your ignorance amazes me.
Originally Posted by Chimmike
ahh the joy of off-topic. Emo-riffic!
kasonb is offline   Reply With Quote
Old 02-17-2006, 09:22 AM   #12
DevlynSyde
OT Whore
DevlynSyde's Avatar
you're the only one saying 4500 for the kit.. where'd you get that number from? lawl.
Vote Dev for OT Mod
Old 02-17-2006, 09:30 AM   #13
rspecv
turbo boosters
Send a message via AIM to rspecv
let me see it bling! Wish i had the money to go vq!
FS: Qr27de build motor ($3500 Shipped) http://www.b15sentra.net/forums/show...92#post2035692
rspecv is offline   Reply With Quote
Old 02-17-2006, 09:59 AM   #14
Bobby Digital
Huge Member
Send a message via AIM to Bobby Digital
2. Wiring harness
4. Belts/Hoses???
5. ???
6. Profit
On a serious note, excellent work here Travis. Now we can longer flame n00bs when they ask if they can put a Maxima engine in their Sentra
.::Bobby::.
Originally Posted by david
Not having to make a monthly payment is a much better feeling than having a fast car.
Bobby Digital is offline   Reply With Quote
Old 02-17-2006, 10:40 AM   #15
Trav4011
Hoosier Daddy?
http://www.fi-r.net/images2/VQ%20Ins...structions.pdf
Just finished the install instructions...
I hate doing **** like that..
Travis
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
