B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Modifications - Performance
Register Home Forum Active Topics Parts Catalog FAQ Search Today's Posts Mark Forums Read
Old 08-16-2005, 02:26 PM   #1
david
Site Admin
Superpro trailing arm bushing Install | Impressions
I got these in the mail yesterday. I was bored so I decided to install them. I've done a Nismo bushing install before so I knew what was involved. As some of you know ES did develop some a little while ago but they have never made it out to production. Superpro is a very well known company in Australia making many things for Nissan among other models. The g20 sports upper link bushings from them as well. Everything has always fit very well and was engineered well.
Now onto the install.
The whole rear beam of the b15 can be dropped with a total of total of 13 bolts (21 if you include the lug nuts)
Start by jacking the car up and putting jackstands under the pinch welds. Also a good idea to put some blocks in front of the front wheels.
Tools specific to dropping the rear beam.
10mm wrench or socket
14mm wrench or socket
17mm wrenches (2) and socket as well
pliers or something similar to remove brake line bracket holder
Now remove the rear wheels.
Unbolt the calipers (just the calipers not the torque members). (14mm)
Remove the clip holding the brake line to the beam.
Unbolt the 2 10mm bolts that hold the e-brake line to the trailing arm.
Now zip tie up the caliper out of the way.
Remove the lower strut bolt holding it to the beam (17mm)
Above the center of the beam you will see a single 17mm bolt holding the lateral link to the car.
Place a jack under the rear beam until it is supported.
Remove that bolt.
Now all that is left is removing the trailing arms.
Remove the 17mm bolt. *note* on the drivers side you may have trouble backing out the bolt to remove it as it hits the heat shield for the gas tank. You may be able to get that heat shield off but I have never had good luck with it. Its easiest just to make a few dents so you can get the bolt out.
Thats it, wheel the rear axle away, its free.
To get the whiteline bushings in you end up re-using the metal casing and burning out the rubber bushing.
Burn around the outside of the metal and you will start to see the rubber delaminate from the sleeve. Do this all the way around the outside of both sides. Then push the bearing out. (careful not to burn yourself)
You may have to do some burning of rubber inside the casing that didn't come out. Clean the surface so it is smooth.
Now its time to install the bushings.
The bushings come with grease. Lube up the inside of the casing. Then put some on the part of bushing that will slide in. Then also put some on the metal sleeve and slide that in.
Now wasn't that easy...... well it was but you aren't done yet.
The brackets that hold the trailing arms in place have some positioning tabs that will interfere with the new bushings.
Remove the brackets from the car (4 17mm bolts)
Here you can see that tab.
To remove it there is a spot weld you can drill out on the other side. Then with a hammer and chisel you can knock it free. This part may take you the longest depending on what tools you have at your disposal.
Once the tabs are off, clean up the surface so it is smooth. Might want to throw some spray paint on there as well so it doesn't rust.
Re-install the trailing arm brackets.
Re-install the lateral link bolt.
Re-install the trailing arms. (make sure the e-brake cable are routed properly)
Re-install lower strut bolts
Re-install caliper
Re-install e-brake cable holder bolts
Re-install brake line clip
Re-install wheels.
Go out and enjoy the fruits of your labor.
Impressions: I'm constantly trying to make my car handle less boat like. It doesn't handle bad but still not to my liking. The car has koni shocks with 350 in/lb springs all around. A lower control arm brace which greatly helped turn in. Still the car has never really rotated to my liking.
So I took the car for a drive to see if I could feel any difference. My fear is I would feel no difference. Well after 2 turns that fear was quelled. The car finally rotates like it should. I'm very impressed just a few bushings made the car handle so much better.
A much better install howto will be coming along.
If you want a set of these, Chuck a long time member of the se-r community is selling them.
Look here:
http://www.b15sentra.net/forums/show....php?p=1655532
b15 with a spud
g20 sporting b15 SE wheels 240k!!!
rusting NX track car with a replacement
i35 new daily driver
david is offline   Reply With Quote
Old 08-16-2005, 02:32 PM   #2
lawngn0mex
Lets do this I'm a cashew
Send a message via AIM to lawngn0mex
DO you know if they fit the Spec-V rear beam? I've heard / read conflicting things about it being different from the SE.
***edit I can't believe I missed that GB thread.
-Misanthropic Gnome
Originally Posted by txspeccer
Pure stupidity, but what else should I expect. Nothing but reactionist politicians and an underinformed public.
2009 Black Subaru WRX
2004 blackout Spec-V
lawngn0mex is offline   Reply With Quote
Old 08-16-2005, 02:35 PM   #3
pugnex
King of OT
Are these bushings included in the nismo bushing kit, or are these a different location?
2004 1.8 in blackout w/ Pacesetter SS+ ES bushings, 80a shore MM, OZ Matrix Elite cs180, Eclipse 8455, DLS A5, eD 11kv2, RL water wetter
pugnex is offline   Reply With Quote
Old 08-16-2005, 02:35 PM   #4
david
Site Admin
Ironically they fit the N15, N16, B14, B15 and P11
Nissan didn't change the trailing arm bushing size. The only thing they did change was make the beam itself thicker. The mechanics are the same.
b15 with a spud
Old 08-16-2005, 02:37 PM   #5
david
Site Admin
Yes, in the Nismo kit you have to press out that whole casing. This is a good alternative if you just want the bushings that really count. Plus whiteline makes some bushings for the front control arm that actually increase castor I am thinking of getting. Then the remaining ones I believe you can get from ES.
b15 with a spud
Old 08-16-2005, 02:38 PM   #6
lawngn0mex
Great info David! Thanks!
Dave / Pugnex:
These look to be Polyurathane, which makes them worth so much more than the hard rubber nismo ones.
Except for the fact the nismo one is a whole kit.
-Misanthropic Gnome
Old 08-16-2005, 02:39 PM   #7
pugnex
King of OT
Hmmm, interesting....I'm sure the install would take me much longer than the 3-4 hrs you originally specified, based on my previous install times, but it seems to be worth it.
Old 08-16-2005, 02:44 PM   #8
david
Site Admin
Probably took me much too long to get those positioning tabs out. Plus I took things out in the wrong order so I could have gotten done much faster. If I did it again I'm sure it could be done in 2 hours or so.
b15 with a spud
Old 08-16-2005, 02:46 PM   #9
piknockout
STU STi Build Complete
piknockout's Avatar
Send a message via AIM to piknockout
Great write up David, they should come in handy when I go to install mine. For only $55 to get some better handling, I'll try it out. I bet I have to take off my RSB first though, that thing is such a bish to deal with and adjust.
2006 Subaru Impreza WRX STi - Pics - Formerly 2003 Sunburst SE-R Spec V
3 STU - 2006 Philly STX Champ - 2007/2008 WDCR STX Champ - 2007/2008 A.I. STX Champ
Sponsored by Agile Automotive Performance
piknockout is offline   Reply With Quote
Old 08-16-2005, 03:33 PM   #10
pio!pio!
Send a message via AIM to pio!pio!
David: let us know if that Whiteline anti lift kit offset bushing thing actually fits B15s
I've been eyeing that part on the Whiteline website for some time now....
2002 Nissan Sentra SE-R Spec V Blackout
The Sig monster ate my sig
pio!pio! is offline   Reply With Quote
Old 08-16-2005, 03:59 PM   #11
SR20DE_MAN
Canyon junkie! ( ^o^) <3
SR20DE_MAN's Avatar
Send a message via AIM to SR20DE_MAN Send a message via MSN to SR20DE_MAN Send a message via Yahoo to SR20DE_MAN
This sounds like a thing to do to my car as well. I think I'm gonna get a set for the front as well!
Former 2000 Nissan Sentra SE owner. Now I drive a little & underpowered "girly" NA8C car that can own many big & overpowered "manly" cars on a good chunk of canyon roads & road courses. Go NA8C! \(^o^ ) <3
SR20DE_MAN is offline   Reply With Quote
Old 08-16-2005, 04:24 PM   #12
lawngn0mex
Fronts? details?
-Misanthropic Gnome
Old 08-16-2005, 09:20 PM   #13
silversurfer
Southern Shift Racing
silversurfer's Avatar
Wow, this is great news. For $55 you can't beat it, not to mention this is probably the next best thing to a RSB. And the install doesn't seem too hard either. Thanks for the write up David.
03 Silver SE-R V
6 DSP- 2007 CCR SCCA Champ
Southern-Shift Car Club
silversurfer is offline   Reply With Quote
Old 08-17-2005, 08:17 AM   #14
piknockout
piknockout's Avatar
So, do you think it would be too much if you already have a RSB? Or do I just need to test it out for myself!
Old 08-17-2005, 09:02 AM   #15
vector03
Send a message via AIM to vector03 Send a message via MSN to vector03
Cut the trail
Originally Posted by Rage Against the Machine
Make a move and plead the fifth 'cause ya can't plead the first
vector03 is offline   Reply With Quote
vB code is On
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
