tony22r's - 2002 Sentra GXE 1.8L (QG18DE) 5-speed - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > News & Introductions > B15 MEMBER RIDES
Thread Tools Rating: Thread Rating: 4 votes, 3.00 average.
Old 01-12-2005, 02:58 PM   #1
tony22r
'02 QG18DE
==MODS==
* Ghetto Airbox
* Unorthodox Racing Underdrive Pulley from Greg V @ Mossy Performance
* EGR Removed, except for that part that plugs into harness (to avoid safe mode).
* Weight Reduction: 249 lbs
Gutted interior, among other things..
Inspired by fluid1mobile. It's ugly, but it's a lot quicker now.
Wondering how something comes apart or is held together in your b15?
Ask me.. chances are I've probably taken it off !
* Bypassed Coolant to Throttle Body
* Gutted Pre Cats in Stock Exhaust Manifold
* Gutted Main Catalytic Converter
* Knock Sensor Relocated & grounded
* Pacesetter Short Shifter #01-0422 from mach1car.com. $69.95 + free shipping.
Install? All I can say is after this you'll be Intimately familiar with the underside of your Sentra! Read the excellent write-up by 1SentraNotEnuff, has great pics.
* generic Straight-Through muffler; 5.5" round canister x 14" long, single slash cut tip. kept factory resonator (previously I tried gutting the stock muffler; that was a big mess, and was still restrictive as hell)
* Red Line MT-90 gear oil - really smooths out the 5-speed, but still not as slick as a civic or miata tranny.
==MISCELLANEOUS==
* Borbet Type B 15"x7" wheels + Yokohama Avid T4 195/50-TR15 tires
* Momo Monte Carlo 320mm leather steering wheel + Hub Adapter #3514 from www.ltbmotorsports.com. Tip for removing airbag... Torx #30 Tamper Resistant (hole in the middle)... or Dremel cutoff wheel like i did..
* PCV Oil Catch (gurov's DIY ~$20 catchcan)
But plan to bypass PCV completely to eliminate blowby into intake @ WOT .. by using bigger catch can & blocking off PCV to intake.
* Removed Air Conditioning.
This is moot now, but much prior to removing AC, I Disabled Automatic AC on Defroster
* Trimmed Throttle Cables
==TO-DO / WISH LIST==
* -DONE- phenolic Spacers for intake manifold & throttle body? I've heard of some nice gains on other vehicle makes. Also an excuse to take the intake manifold off so I can port it.
(installed Outlaw Engineering Thermoblock spacers, port-matched intake manifolds)
* Lightweight Flywheel & HD Clutch - gonna try to do this first so don't have to take apart exhaust twice later. Anybody got links to good Write-ups on replacing flywheel & clutch on a QG18 ?
* Header - probably HotShot + a couple of O2 sims to keep codes away.
* CAMS!!! + Springs, Retainers, etc... - Come on JWT!! (sign Petition here).. make Cams for our QG18DE and we will BUY them!
* LIGHTER rims - my stock 14" steelies with 185/65-14 tires only weighed in at 30 lbs! I want 15" rims & 50 series tires that are LIGHTER than That!
(4/114.3mm bolt pattern, 66.1mm hub bore) Check out www.wheelweights.net for the scoop on Light Weight rims.
* relocate Battery to trunk - are Optima batteries worth it? I guess that would eliminate a plastic box and having to vent it.
* Carbon Fiber Hood - Who makes good CF Hood kits w/ complete hardware for the QG18? Priorities to me are good Fit and easy Installation. Any owner reviews/suggestions would be appreciated.
* OBDII code reader - probably Actron, $150 at Autozone. It'd be nice to be able to read/erase codes without bumming a reader from Autozone every week, which is how often my EGR Block-Off throws codes. Are there any affordable "Consult II" ones? I've heard an '02 QG owner advance his timing at a dealership with a Consult.
* Exhaust - hmm.. prolly a full Stromung system, and replace main catalyic converter with downpipe.
* Suspension - I wanna lower it, so prolly Tein coilovers with adjustable height. Beefier front Stabilizer Bar. Does anyone make a REAR stabilizer bar for the QG18? And put in aftermarket bushings.
* Strut Tower Braces - front & rear. Does anyone make Rear Strut Braces for the QG18? If not, I'll have to fabricate one.
* more Weight Reduction - if my car can run without it... it's comin OFF!
There's still a lot more stuff to go!
* maybe a chin spoiler on the front like on 350Z. maybe a wing on the back - something different, maybe low Nascar-style like on Chev Monte Carlo SS
* pass Calif Smog Check in Oct 2008? I'll be keeping my oem stuff in case I can't find a smog tech I can bribe.
==SPECS==
* Top Speed: 122mph @ ~5750rpm 5th gear
(~55 deg F. Elevation=3000ft. Apple Valley, CA 92307)
* Dyno: N/A
* Curb Weight: 2355 lbs (estimated)
==FAVORITE LINKS==
* Forums
http://www.b15sentra.net
http://www.nissanforums.com
http://forums.thevboard.com
http://www.gtasentra.net/board
http://www.southern-shift.com/forums
* QG18DE Stuff (What does qg18de mean?)
http://www.nissanperformancemag.com/...rojectqg18.php ..Project QG18DE, some good mods & pics
http://www.nissanperformancemag.com/projects/qg18de.php ..QG18 Turbo
http://www.sentra.net
http://www.nissanusa.com
* How-To's and Tutorials
http://forums.thevboard.com/viewforum.php?f=47 ..3 pages of Great How-To's!
http://www.jimwolftechnology.com/tech_details.asp ..some good .PDF Tech How-To's
http://www.southern-shift.com/manual.htm ..B15 Factory Shop Manual in .PDF format
http://www.gtasentra.net/howto.html ..some good stuff
www.wheelweights.net ..good list of wheels and their weights
* Vendors
http://www.b15sentra.net/forums/forumdisplay.php?f=65 ..Mossy Performance Forum
http://www.mossyperformance.com/main ..Mossy Performance Website
www.tirerack.com ..good place to get tires, some wheels
www.ltbmotorsports.com ..good selection of Momo/Sparco steering wheels, hub adapters
http://www.ptuning.com/html/discount...id=ptspecplace ..code gives 5% discount
Happy tuning, ride safe...
-tony22r
tony22r is offline   Reply With Quote
Old 01-12-2005, 03:02 PM   #2
txspeccer
Welcome?
Originally Posted by Fireman0605 View Post
oh B15sentra Banned Me For No Reason Again And Its Ok Wit Me Because I Guess I Got To Be White In Order To Be Like And Talk Like Im White Too. u have the very lack of KNOWDELGE. So get cha mind right FOOLS...
txspeccer is offline   Reply With Quote
Old 01-12-2005, 03:12 PM   #3
OkToBeR
200,000?
is this a joke? it's written like a 12 year old boy's diary and there are no pictures.
anyone who contributes winning a race to a 'ghetto' air box and a UR pulley and lists 'no hubcaps' as a mod has some issues.
2004 Sapphire SpecV - Injen intake, SR-S Header+midpipe, Kenwood head unit, NISMO wheels w/Kumho SPTs, and Thule roof rack (retired for now 150,000 miles)
How2-Brakes - How2-FrontLowerArms
2011 Subaru Impreza Outback Sport - replacement
OkToBeR is offline   Reply With Quote
Old 01-12-2005, 03:13 PM   #4
sixspeednismo
Send a message via Yahoo to sixspeednismo
And I am a cancer and I like long walks on the beach..............
Alpine 7995 -- CDT-cl61 Comps--U.S. Acoustics 2100 amp
sixspeednismo is offline   Reply With Quote
Old 01-12-2005, 03:16 PM   #5
sje0123
1st Pwner of B15sentra
Garage
Send a message via AIM to sje0123
What are you talking about? My ghetto intake added atleast 20 whp. I took a garden hose and attached one end to my intake and ran the hose through the car and out the trunk and attached it to my exhaust. Now there is no power loss because it is all being put back into the engine when it tries to leave the exhaust. It's called recycling.
Sentra is Gone!
sje0123 is offline   Reply With Quote
Old 01-12-2005, 03:19 PM   #6
txspeccer
LMAO!
I can just see someone trying that and calling it a ghetto turbo...
Old 01-12-2005, 03:27 PM   #7
NiteRider11
CDN_R Tune XE
wow....welcome to the boards...now buy some real mods
New Set Up..QR25DE..Bolt ons with 75shot
Old Set Up..All Motor/Nitrous..Fastest All Motor 1.8L
www.1320drag.com
R.I.P Tj Stutt 1986-2004
NiteRider11 is offline   Reply With Quote
Old 01-12-2005, 03:27 PM   #8
01GXESentra
Send a message via AIM to 01GXESentra
2001 Radium GXE Sentra
Magnaflow Muffler|Cold Air Intake|Tinted Windows|Ghetto Grille|Removed Badges|
SHIFT_Performance
01GXESentra is offline   Reply With Quote
Old 01-12-2005, 03:28 PM   #9
tony22r
'02 QG18DE
Old 01-12-2005, 03:59 PM   #10
MN01GXE
Owner
Send a message via AIM to MN01GXE Send a message via MSN to MN01GXE Send a message via Yahoo to MN01GXE
just a few comments (welcome and happy searching!)...
* header - hotshot is used by plenty, I believe one or two other companies make a header for the qg18de, but I could be wrong.
* carbon fiber hood - Everything I have heard has me leaning towards a VIS OEM CF hood (pm Blazetiger and be patient, he should be able to hook you up.
* your wheel bolt pattern is 4x114.3 (see faq on this site).
* OBDII code reader - worth it if you like to troubleshoot on your own, but you can get everything from a little box that spits out the code number to full-on data logging capabilities. A little research should tell you what suits your needs and wallet.
* short shifter - take a look around, personally I don't have one, but some of the site sponsors will have some for sale, and searching this forum should turn up what others here have used.
* exhaust - take your time...this one is mostly about quieting the sound of your header (when you get one). Several companies make decent catbacks, or you could do fine with custom 2.25" piping and a high-flow muffler (search around for resonator and muffler recommendations.
* suspension - springs and dampers from a spec bolt right in, as do the sway bars...but if you are going to spend the money, might want to do a little research and step up to something AFM. If you really want the spec springs/dampers, this guy has them for sale for $100: http://www.b15sentra.net/forums/showthread.php?t=102272
* strut tower braces - several companies make a front upper strut tower bar, none for the rear. Nismo and one guy out of his garage both make lower bars that tie the control arms together.
2008 Chevrolet Silverado 1500 LT1 Z71
02 SE-R - Konig Traffiks w/ Azenis RT-615, Nismo FSB, Tanabe Sustec 4pt Brace, Nismo hard rubber bushings, Tarmaq RTB, //TMS CB, Injen CAI, fuel filler cap holder
01 GXE (autox #365) - 91.9whp - RIP 02/06/2007
MN01GXE is offline   Reply With Quote
Old 01-12-2005, 04:15 PM   #11
Terranismo
Fully Bolted + Juiced!
Originally Posted by tony22r
* Bypass Coolant to Throttle Body - soon as it stops raining around here.
* header - prolly HotShot unless someone else makes one for our car.
* carbon fiber hood - Priorities to me are good Fit and easy Installation, I don't wanna have to Mess with stuff/fabricate things just to get the windshield sprayers to work, etc. Who makes a decent carbon fiber hood kit (w/ complete parts) for our cars? Any owner reviews/suggestions would be appreciated.
* 15" aluminum rims + 195/50 tires - I'm really smitten by the OZ Rally rims on Mitsubishi Lancers! I've seen bronze and silver varieties. Can somebody tell me if they're 4-100mm with similar offset? If so, I'm gonna go out and get me 4 of these!
My stock tires/rims now are 185/65-14" on 14"x5.5, 4 on a 100mm with 41mm offset i believe.
* OBDII code reader - I heard about Actron(?) code readers starting at $169 ? I plan on tripping my SES light a LOT, so it'd be nice to be able to chase codes down without bumming a reader from Autozone every week.
* short shifter - is there Anyone that makes one for the QG18DE? I've heard Pacesetter?
* Replace steering wheel with non-airbag 10" Grant, maybe Sparco.
* phenolic spacers for intake manifold & throttle body ? maybe.
Mostly an excuse to take the intake manifold off so I can port it.
* exhaust - hmm.. haven't really thought about different muffler brands.
Was considering gutting my main cat if i can get away with it. I used to gut cats All the time when I wasn't living in CA! Or i heard someone say SER cats flow good?
* suspension - struts/springs/stabilizer bar(s?) from an SER Spec V.
Um.. Does suspension from a 2.5L SER Spec V bolt right up to a 1.8L QG18DE?
If so... any Spec V owners out there wanna unload all their old suspension part$ to me? (southern California only please, I wanna see the parts first)
* strut tower braces - front & rear.
* a wing on the back - for grins and giggles, and my 7-yr old son would really dig it.
Ok you questions can be answered if you search a little. Instead of being a nazi I'll try to help you out with some:
Header: Get a Hotshot. Weapon R also makes a header but it was actually designed for the GA16DE engine on the old Sentra (read: pre-B-15).
Wheels: Get some lightweight wheels (probably Speedline, Team Dynamics, OZ Racing, etc), it's just personal preference really. As always research weight on each type and don't just go by word of mouth. If you're planning on brake upgrades in the future get at least a +2 increase (meaning 16 inch wheels).
Short Shifter: The ones made for the B14 SR20DE work on the QG18DE, including Pacesetter, B&M, etc. Also get some Energy Suspension shifter stabilizer bushings while you're at it (they cost less than $20.00).
Ported Throttle Body: haven't seen anyone do it on their QG here but you can PM Garland and he'll get a 55-66mm port done for you at $30.00.
Exhaust: Get a bolt on cat-back for a B-15 SE or have one custom made. Don't go over 2.0-2 1/4 tubing becuase you'll lose power down low and get a big resonator with oval entry/exit.
Suspension: Go with Teins damper/springs combo, Eibach Sportline/Koni Yellow shocks, Nismo, etc. Stick with the name brands don't buy any "ricer" crap and you should be ok. Just don't stick lowering springs or sleeve coilovers on your stock dampers as it will shorten their life. A good way to get the correct setup is to either ride in a B-15 near you with some combo on, or read up on people's experiences here.
Strut Tower: same as advice on suspension. Many brands, many opinions, just search.
2004 X-Trail S/T AWD 5-Speed: Fully bolted!
2003 Skoda Octavia Ambiente FWD 5-Speed
1992 & 1988 Nissan Terrano 4WD 5-Speed
Terranismo is offline   Reply With Quote
Old 01-12-2005, 04:17 PM   #12
Terranismo
Check out www.mdhall.com for more info about how you can modify your car.
BTW: Welcome
Old 01-12-2005, 04:24 PM   #13
BleedGarnetB15
Bleed'N Garnet YO!!1
Send a message via AIM to BleedGarnetB15
WTF dude what are you talking about? buy an intake what is a Ghetto air box?????
2006 Scion xB
R.I.P. 2K2 B15
www.myspace.com/Riddell54
www.swatautomotive.com
BleedGarnetB15 is offline   Reply With Quote
Old 01-12-2005, 04:29 PM   #14
tony22r
'02 QG18DE
Hey thanks for the heads up on the parts, I appreciate it.
We just bought a house, budget's pretty tight so for now I'm doing whatever's "Free" or cheap.
On a side note, are you close to Indianapolis, Indiana ?
There's a company out there http://www.outlawengineering.com/index.html
that make "intake spacers" looking for test cars for R&D. I hear incentive is a free set of intake & TB spacers if they use your car.
I came across this by accident on a VW forum discussing "phenolic spacers reducing heat soak to intake manifolds"...
Happy tuning, ride safe,
-tony22r
Old 01-12-2005, 04:33 PM   #15
MN01GXE
Owner
...On a side note, are you close to Indianapolis, Indiana ?
that make "intake spacers" looking for test cars for R&D. I hear incentive is a free set of intake & TB spacers if they use your car....
[threadjack]
per their site...
Do you own one of the following vehicles?
• 92-93 Acura Integra GSR B17A1 DOHC VTEC
• 90-93 Acura Integra GS/RS/LS B18A1 DOHC
• 95-00 Chrysler/Dodge Avenger/Cirrus/Sebring/Stratus 2.4L L-4
• 91-96 Ford Escort GT/Mercury Tracer LTS 1.8L BP DOHC
• 89-91 Civic SI/CRX SI 1.6L D16A6 SOHC
• 92-95 Honda Civic/DelSol 1.5L D15B SOHC
• 92-95 Honda Civic EX/SI 1.6L D16Z6 SOHC VTEC
• 96-00 Honda Civic CX/DX/HX/LX 1.6L D16Y5/7 SOHC
• 96-00 Honda Civic EX 1.6L D16Y8 SOHC VTEC
• 93-01 Honda Prelude VTEC H22A1/A4 2.2L DOHC
• 90-93 Mazda Miata 1.6L B6P DOHC
• 94-97 Mazda Miata 1.8L BP DOHC
• 99-03 Mazda Miata 1.8L BP DOHC
• 90-94 Mitsubishi Eclipse/Eagle Talon/Laser 4G63T 2.0L DOHC Turbo
• 95-99 Mitsubishi Eclipse/Talon 4G63T 2.0L DOHC Turbo
• 96-99 Mitsubishi Eclipse Spyder/Galant 4G64 2.4L
• 95-98 200SX SE-R/G20 SR20DE 2.0L DOHC Low Port
Then Outlaw Engineering needs you!
Would you like a FREE performance modification installed on your car? If you own one of the models listed above and live in the Indianapolis area you have the opportunity to take part in the development of a new ThermoBlok spacer kit specifically for your car. For your trouble, you will be rewarded with a FREE set of ThermoBlok spacers installed on your ride."
No nissans on the list
[/threadjack]
