Where is the turn signal flasher on a 2000 Sentra GXE?
I took the steel brace under the steering column off and finally found it to the right of the steering column & up a little.
Now my question is, How do you go about getting it apart without breaking anything. I can just barely touch it with one finger.
Do I pull down on the plug?
Does the flasher pop out somehow?
Do I push up on the flasher?
It looks like it may pop into the piece of steel it is next to.
Do I try to get a long screwdriver in there and pry it away from the steel?
I don't want to break anything by going about it bass ackwards
Are there any little tabs that have to be pried or anything?
Found out it's much easier to also pull the trim under the radio.
There are 2 small black tabs that need to be popped to remove the OEM flasher.
If you wedge a screwdriver in between the steel and the Relay, it easily pops off to get it where you can change the flashers
