Spring Rates Rundown (Stock and Aftermarket) - Page 3 - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
Thread Tools Rating: Thread Rating: 52 votes, 4.92 average.
post #31 of 178 Old 07-07-2005, 01:40 PM
Ni55anPAT
Former SE granite hotness
Quoted: 0 Post(s)
Send a message via AIM to Ni55anPAT Send a message via Yahoo to Ni55anPAT
Nice post !
07 350z VQ35HR - SOLD
99 Cherokee Sport *DD*
Yamaha GPR1200 - SOLD
Ni55anPAT is offline
post #32 of 178 Old 07-07-2005, 01:40 PM
JohnO
Casual Lurker
JohnO's Avatar
Quoted: 0 Post(s)
Originally Posted by Sunburst03
lol.........i never said i knew the exact steps needed to take in order to effectively double the rates.......i just know that after talking with numerous racing teams at events i've attended as well as guys who work for the suspension companies i've been told across the board that if you preload the springs the right amount it will effectively double the rates
i'm sure that there is an equation or process though somewhere out there on how to figure this out
most people don't realize what spring preloading can do for you if you set it up properly (you can effectively double your spring rates just from preloading them
2002 Molten Silver Spec V
"The irony of the Information Age is that it has given new respectability to uninformed opinion." - John Lawton
JohnO is offline
post #33 of 178 Old 07-07-2005, 01:45 PM
Sunburst03
Endless USA S13 Silvia
Quoted: 0 Post(s)
Send a message via AIM to Sunburst03
Originally Posted by JohnO
so most people includes you???
look if you have a problem with me that's fine.......i couldn't care less to be honest......but please refrain from distracting every thread that i post in
and i never said that i fully understood the benefits of spring preloading did i??? nope didn't think so
1992 S13 Silvia (RB25DET ), 1995 ECR33 Skyline *sold* (will be missed), 2003 Spec V *sold* (won't be missed)
Sunburst03 is offline
post #34 of 178 Old 07-07-2005, 01:46 PM
cortrim1
Boost Addict
Quoted: 1 Post(s)
I asked the suspenion guru at work and he said that preloading the spring does not change the spring rate only the point at which the spring starts to compress.
http://www.cardomain.com/id/cortrim1
www.southern-shift.com
94 se-r 300whp flat black terror
92 se-r Sr20VE powered DD
cortrim1 is offline
post #35 of 178 Old 07-07-2005, 02:01 PM
SR20dee
2busy4b15/but watch it
Quoted: 0 Post(s)
johnO : lets try not to thread crap the sticky.. thanks.
GET INTO RACING!!!
www.ner.org www.nescc.org www.fcscc.com www.scca.org
01 Nissan Sentra w/PP(167K mileswith new rear brake calipers. )
11 Toyota 4Runner(55000 mile Tank )
SR20dee is offline
post #36 of 178 Old 07-07-2005, 02:38 PM
Sunburst03
Quoted: 0 Post(s)
hmmmm........could you ask him what if any benefit there would be if you were to preload the springs an extra 50%??
what i mean is.......instead of just making the springs secure so they don't flop around when you jack up the car.........you were to preload them twice as much......does that make any more sense lol
post #37 of 178 Old 07-07-2005, 02:48 PM
fluid1
Sentra God
Quoted: 0 Post(s)
Send a message via AIM to fluid1
this is why I sarcastically asked Danny boy if he could let me know how to increase spring rates by preloading
fluid1 is offline
post #38 of 178 Old 07-07-2005, 02:50 PM
cortrim1
Boost Addict
Quoted: 1 Post(s)
you mean to get rid of unchecked spring travel. I was told that preloading the spring will give a rough ride since you are cutting down on the spring travel. the force that usually absorbed by the spring will be transmitted directly to the upper mounts. example if you have a 40lb spring and put 2" of preload on it then hit a bump that puts 40lbs of force on the spring. the spring will not move nor will it absorb the load properly. As for unchecked movement there is a measurement that can be made to check if you have too much. to measure you need to look at the bottom perch. you will notice that the perch has a flat side that is about 1/4 tall that tappers to a angle. If you can move your spring far enough off the perch that the bottom of the spring reaches the angle on the perch the car is too low. All this has to be done with the car jacked up.
cortrim1 is offline
post #39 of 178 Old 07-07-2005, 02:56 PM
Sunburst03
Quoted: 0 Post(s)
yes unchecked spring travel........thank you........i had it on the tip of my tongue just couldn't say it lol
i see what you're saying about preloading the springs........hmmmm........i wonder what they meant then when they said you could effectively double your spring rates .......i would like to think the guy knew what he was talking about since he used to be an engineer for Tein and is now an engineer for Zeal
post #40 of 178 Old 07-07-2005, 03:03 PM
cortrim1
Boost Addict
Quoted: 1 Post(s)
preloading will make the suspension stiffer but will not change the spring rate. If you you made the suspension stiffer if could be like doubling the rate with out changing the spring. I have put springs in the compression tester at work and can tell you that no matter how far its compressed it will measure the same if its a linear rate spring.
cortrim1 is offline
post #41 of 178 Old 07-07-2005, 03:05 PM
Sunburst03
Quoted: 0 Post(s)
hmmmmmm.........that could be what he meant by doubling the spring rates
i wish i could remember his name so i could call and ask the guy what he meant
post #42 of 178 Old 07-25-2005, 09:44 PM
armypilot84
Quoted: 0 Post(s)
so does that totally mean that you cant use the megan springs without stiffer dampers?
armypilot84 is offline
post #43 of 178 Old 07-25-2005, 10:00 PM Thread Starter
Dangling Fury
Immature Tough Guy
Dangling Fury's Avatar
Quoted: 0 Post(s)
(Thread Starter)
It doesn't matter if you use stock dampers or konis, a 2" drop is way too much for stock length dampers. Also, users have reported that the drop is uneven front and rear. Sorry, but I would stay away from this product.
2006 Mitsubishi Evo IX RS (300whp/298wtq)
2002 Nissan Sentra SE-R (sold 7/26/07)
Central Carolina SCCA (Autox for NC/SC)
Dangling Fury is offline
post #44 of 178 Old 08-30-2005, 07:05 AM
(HK)
Quoted: 0 Post(s)
DanglingFury
Board won't allow me to send you a PM (cause I'm probably a newbie) but here is my question.
I run a R33 full bodykit and I am an IASCA competitor. I have a custom fiberglass install thats weighing me down (more like sagging). I have the stock springs all around so that I can clear most damaging Montreal streets. I would like to drop my front end so that I can actually enjoy some of my performance mods and not just spin through. What in your best opinion would help me out most? Custom made springs? or Coilover set?
Your thread is incredibly complete but no one considers us Audio Enthusiasts whom enjoy performance as much as sound. Any info would be greatly appreciated. If I was to guess I have probably 250-300lbs of gear in the trunk.
Thanks, to all that might shed some light on the subject
2003 IASCA SQ ROOKIE 601+ WORLD CHAMPION
(HK) is offline
post #45 of 178 Old 08-30-2005, 07:49 AM
Sunburst03
Quoted: 0 Post(s)
It sounds to me like your best bet is going to be a full set of coilovers. They will permit you to adjust your ride height to your liking i.e. you can slam the car at the show if you so chose and then raise it all the way back up (still lower than stock ride height) when you are done at the show. Also, you will be able to adjust the ride height independently from front to back in order to accomodate for all of that junk in your trunk
Late,
Daniel
User Tag List
