My P0335 Cranck Position Sensor woes - Page 3 - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
post #31 of 34 Old 10-30-2012, 02:58 PM
is your abs or airbag light on along with the ses light? what happens when you try to start it up, do you hear relays? does it studder but not start? do your interior lights work? have you pulled the ecu yet and made sure it isnt a rust box?
i68k is offline
post #32 of 34 Old 11-01-2012, 07:58 PM
rogergm62
I have found my timing chain stretched... so i'm gonna replace it....I will post pictures later...
Another thing... If u have an oscilloscope is very easily to see if you have trouble with you timing chain.
And something more... the service manual is incomplete... cause I never find info about the camshaft position sensor (POS)...
The service manual says P0335 could be because the signal is not in the normal pattern... but never tells you what a normal pattern means...
I'm gonna post pics later about what a normal pattern means later...
rogergm62 is offline
post #33 of 34 Old 11-02-2012, 08:26 AM
the pattern should be the readings from the signal plate. the signal plate is that plate that has teeth on it, the teeth pass in front of the poisition sensor, uses them for timing. make sure you take a good look with the chain tensioner and your new chain before install.
i68k is offline
post #34 of 34 Old 11-02-2012, 04:01 PM
rogergm62
Thanks i68k..... But i m talking about the relationship between cam and crank. About how this signals look... And what a normal pattern means to the ecm.... The service manual shows the signals individually but not how they work together....i am almost done with this issue... Next week i will post all my job..
Sent from my SAMSUNG-SGH-I897 using AutoGuide.Com Free App
