The trunk won't open! - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
post #1 of 11 Old 09-14-2011, 03:28 PM Thread Starter
uscg4good
05' 1.8S
I can't pop the trunk with the fob, and I can't open it with the key either. I suspect the latch is stuck somehow. I was going to climb in there through the back seat but I can't figure out how the back seat comes down??
Somebody please help!
uscg4good is offline
post #2 of 11 Old 09-14-2011, 09:05 PM Thread Starter
uscg4good
Nobody else drives a 1.8?
post #3 of 11 Old 09-15-2011, 01:30 AM
chiquae07
Informed Lurker
Send a message via AIM to chiquae07
the only way i know to put down the rear seats is with the trunk open, and you pull on the plastic knobs on each side of the trunk with the rear doors open. unless they changed it in 04 to a button near the headrest.
you say it wont open with the fob or key? what about the cable on the floor/button on the dash?
Suck up a kitten
Eat a butterfly
Replace with WRX
2001 Granite Sentra Se wit PP
Originally Posted by txspeccer View Post
Slow car races are exciting. For those 19 seconds until you hit 80 mph, nothing else matters.
chiquae07 is offline
post #4 of 11 Old 09-15-2011, 12:58 PM Thread Starter
uscg4good
It won't open with the FOB, key, or dash control.
post #5 of 11 Old 09-15-2011, 01:08 PM
mirrortints
VVL is good
Garage
Wow, this is like the 3rd person in a month. Are you using the valet key?
2001 Sentra SE
mirrortints is offline
post #6 of 11 Old 09-15-2011, 06:02 PM Thread Starter
uscg4good
I don't know what a valet key is.
It's just a regular key, a piece of metal shaped such that it moves the right things inside the cylinder to allow the lock to be open.
It worked fine until just recently.
post #7 of 11 Old 09-15-2011, 06:51 PM
as i suggested on the other threads, since this happened to me a few times years ago. apparently nissan does NOT have a lockout procedure other than removing seats.
if you have a 60/40 split rear seat, you can use a broomstick thru the rear seat to hit the glow-in-the-dark safety trunk release. once you get this open, there is a dumb lever near the latch, inside the trunk, behind the bumper, not on the trunk lid, the stops the latch from opening. you may need to flip that lever. if the glow-in-the-dark needs to move either left or right, but if this doesnt release the trunk you have mechanical problems.
i68k is offline
post #8 of 11 Old 09-16-2011, 10:51 AM Thread Starter
uscg4good
I just went out to the car and played with it a little. I see what you mean about getting something between the two seats to hit the lever. It's going to be hard though, there is barely any wiggle room between those seats. I just can't believe the seat doesn't fold down? If I jiggle it, it sounds like it is just latched on there, but I can't find any release lever. When I'm get home I'm going to try the broomstick deal.
What a mess....
post #9 of 11 Old 09-16-2011, 08:58 PM
Jeff Kleb
2002 Sentra GXE Owner
Jeff Kleb's Avatar
My 2002 GXE's trunk won't open with the key fob (makes noise, but won't pop); nor will the dash button work. However, the key works just fine.
It'd cost an arm & a leg to fix it.....so I'll just deal with it. The damn thing is ten years old this month and I am just happy it still runs!
2002 Sentra GXE in Molten Silver; 1.8L, 5-speed, Synergy Package. In 2012, it was repainted, had new struts installed, new head gasket, new water pump, new spark plugs, new sensors, and new belts & hoses. 160,000+ "original owner" miles.
Jeff Kleb is offline
post #10 of 11 Old 09-18-2011, 03:27 PM
01GXEStock
Quoted: 3 Post(s)
This thread shows a photo and description of the valet lockout tab. All youse having problems know about this, right?
http://www.b15sentra.net/forums/showthread.php?t=183432
01GXEStock is offline
post #11 of 11 Old 09-21-2011, 02:19 PM Thread Starter
uscg4good
Good stuff, thanks a lot.
