Flywheel Issue - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Technical Discussion
Old 08-30-2011, 04:41 PM   #1
mistertrip
Exclamation Flywheel Issue
I recently purchased an F1 Racing Chromoly Flywheel (http://f1racingclutchsystem.com/products/fwlwc.html) along with their Stage 1 Clutch setup. I had it installed at the Nissan dealership and am having all kinds of problems since then. Twice since the install and inside a month it's been back in the shop. The first time they had to replace the clutch adapter and this time they said that the Flywheel itself looks to be rubbing and causing all the problems as it is thicker than the stock. They are going to replace it with a stock, but I'm wondering if anyone else has had this problem? Anyone put an aftermarket in and had all kinds of issues? This seems really strange to me.
Has anyone had experience with this flywheel? Is there a special setup for aftermarket flywheels in the QR motor and trans?
mistertrip is offline   Reply With Quote
Old 09-12-2011, 10:48 PM   #2
fubar1o2
I heard mostly bad reviews about f1 flywheels and 1 good review. I would doubt it that the dealership would install the flywheel and clutch incorrectly since it's not something difficult. Are you sure you got the right flywheel for your car? That's the only thing i can think off.
B15 S5peed PP SR20VE
Originally Posted by Bullet1212 View Post
well i kno you guys are talkin bout se's but for the ser wit da qr i was thinkin y dnt you get a exhaust system from a new altima wit da dual exaust and just do som fab work to shorten the pipes
fubar1o2 is offline   Reply With Quote
Old 01-22-2013, 01:00 AM   #3
SE-R-
i just had this flywheel installed with the exedy oem clutch. and i m having issues as well. the mechanic said the flywheel is too thing and when the i engage the clutch pedal the clutch pressure plate is not stoping. So its hard to put 1st gear and reverse looking for solution tho.
2003 spec v cloud white.
Nismo intake,Nismo header,HP midpipe,Megan exhaust w/18''&14'' resonators w/vibrant sleeper muffler,Ur crank pulley,Ground wires,D/S rotors w/hps pads,17x7 TSW w/kuhmo 215/45/17,Pioneer Deck w/yellow fogs.
SE-R- is offline   Reply With Quote
Old 01-22-2013, 07:31 AM   #4
not sure on solutions, a lot of people have problems with the f1 flywheel. did your shifting problems start when you installed the new flywheel? hopefully youve checked/changed your gear oil, as a bad level makes it hard to get into certain gears. its always hard to get into reverse, there's no synchro for reverse.
Old 01-24-2013, 08:28 AM   #5
hova04
damn sorry to hear, the reviews are bad though on this product. You should have considered the 2j-racing fly wheel.
hova04 is offline   Reply With Quote
Old 02-03-2013, 11:15 AM   #6
ten-sec Spec
The Black Cloud
Garage
I got the F1chromoly with the stage 1 kit. Mine installed fine.
ten-sec Spec is offline   Reply With Quote
Old 04-08-2013, 08:57 AM   #7
krzysiek033
I had the chromoly flywheel installed last year. Was great on the beginning, but over the winter it started to rattle. Rattle stops when I push the clutch pedal. Sometimes its a little harder to put it to 1st gear. I will probably continue to drive on it until something breaks.
This rattle is bothering me a little because when I remote start my car and is standing on the street it sounds a little like engine going bad which is not true because its from the clutch.
krzysiek033 is offline   Reply With Quote
Old 04-08-2013, 09:15 AM   #8
BuiltQR25
I've installed mine over 3-4 yrs ago no issues what so ever. How well do you know the tech or service advisor at the dealership. I can't believe that they would install your parts.
Sent from AutoGuide.com Free App
BuiltQR25 is offline   Reply With Quote
Old 04-10-2013, 11:53 PM   #9
krzysiek033
I just noticed the rattle stops when I push the shifter lever little to the front. Is there any way to adjust the shifter?
Old 04-22-2013, 09:01 PM   #10
ten-sec Spec
The Black Cloud
Garage
check out the bushings
