Scanner "Connection Error"?? - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Technical Discussion
Old 05-06-2012, 06:57 AM   #1
striker1
Exclamation Scanner "Connection Error"??
Hey all, thank you in advance for any help that you can provide me!
I can't use a scanner to pull codes or anything because the scanner always throws a "Connection Error". Any ideas what might be causing this?
Is the ECM bad?
striker1 is offline   Reply With Quote
Old 05-08-2012, 09:30 AM   #2
there is a fuse for the obd2 connector, checked the fuse? if i remember, its one of the aux/misc fuses
