2006 sentra spec V - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Technical Discussion
Old 04-05-2012, 01:16 PM   #1
99sel-r
2006 sentra spec V WILL NOT REV PAST 2K
B15 friends i need some help my car wont rev past 2k rpms , i was driving on the freeway and the car started acting weird and it wouldnot go past 2krps so i had to pull to the side.
This happen to my 95 ser and it was the MAF not sure if it would be the same with this cars please help.
99sel-r is offline   Reply With Quote
Old 04-05-2012, 02:54 PM   #2
you need to pull the codes. it could be maf or tps failure. there's also a recall for something similar as well which includes an ecu reprogram. are you upto date on your recalls?
Old 04-06-2012, 11:12 AM   #3
99sel-r
This is the code I got p0011.
Old 04-07-2012, 08:50 AM   #4
p0011 - ivt control performance
the most common causes of this code is usually ivt solenoid, crankshaft position sensor, or camshaft position sensor.
have you upgraded your cam&crank to newer type sensors? also check the connections to all 3 sensors just in case its loose or something. check your battery terminals and grounds for good connection.
Old 04-18-2012, 05:17 PM   #5
99sel-r
i will go ahead and replace the cam and crank sensor and see if that fixes the issue
Old 04-22-2012, 01:18 AM   #6
99sel-r
Changed the crank/camshaft and its still didnt fix the problem, car runs great but when the SES check engine light comes on it won't let me rev past 2k RPMs , someone help its getting really frustrating
Old 04-23-2012, 05:58 AM   #7
saint0421
Carrrrrne asada
saint0421's Avatar
You're still in limp mode. Does the same code still exist?
Originally Posted by orangelloSE-R
It looks like a troop of blind urban ninja ghostbusters going hand-to-hand with some ghosts to me.
saint0421 is offline   Reply With Quote
Old 04-24-2012, 08:39 AM   #8
did you get the same code?
have you checked the solenoid is functioning?
there is troubleshooting for this in the fsm.
Old 04-24-2012, 12:06 PM   #9
SparrowSpecV
Driver.
Try the 'rubber glove' technique its on the site somewhere...
'06 Spec V Brembo.
SparrowSpecV is offline   Reply With Quote
Old 04-24-2012, 03:51 PM   #10
B15pwr
Garage
Get a new crank position sensor...
B15pwr is offline   Reply With Quote
Old 04-24-2012, 06:25 PM   #11
99sel-r
change the crank and camshaft sensor already, replaced the variable valve timing control solenoid and same thing code came back. its hard to start and im pretty much thinking the timing is off
Old 04-26-2012, 09:43 AM   #12
im guessing you replaced the solenoid because it didnt work? did you check the voltages from the harnesses? did you work on the car previous to getting this code, changing the timing? the code you have is basically saying that the input the ecu is receiving doesnt perform properly, have you checked the voltages at the cam sensor? are you following the fsm?
Old 04-27-2012, 02:25 PM   #13
99sel-r
problem fix, thanks
Old 04-29-2012, 07:35 PM   #14
what was the problem? to help future viewers
